jackson Posted September 21, 2021 Share Posted September 21, 2021 Where to buy DIESEL fuel ( on the river) Wroxham , also who would be considered the best for engine service etc in that area THANK YOU Quote Link to comment Share on other sites More sharing options...
grendel Posted September 21, 2021 Share Posted September 21, 2021 most of the hire yard will happily sell you diesel fuel. I was once asked whether a hirer or private as the price was different, but never did find out which was cheaper. Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted September 21, 2021 Share Posted September 21, 2021 I did, at Horning, diesel is cheaper if you are a private boat I have my suspicions as to why Gtiff 1 Quote Link to comment Share on other sites More sharing options...
rightsaidfred Posted September 21, 2021 Share Posted September 21, 2021 1 hour ago, jackson said: Where to buy DIESEL fuel ( on the river) Wroxham , also who would be considered the best for engine service etc in that area THANK YOU Boulters Horning for both, cheapest diesel on the Broads and competitive for any work 1 Quote Link to comment Share on other sites More sharing options...
annv Posted September 21, 2021 Share Posted September 21, 2021 Hi Jackson I suggest you only use F.A.M.E free diesel or the new Gas diesel you then wont get diesel bug and if your engine old a deterioration of the rubber seals and hoses. John 1 Quote Link to comment Share on other sites More sharing options...
Chelsea14Ian Posted September 21, 2021 Share Posted September 21, 2021 On the South,as said most hire company yards will sell.Always best to ask in advance if possible.Brooms most times I fill up there,WRC. Beccles across from the YS. Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted September 21, 2021 Share Posted September 21, 2021 1 hour ago, annv said: Hi Jackson I suggest you only use F.A.M.E free diesel or the new Gas diesel you then wont get diesel bug and if your engine old a deterioration of the rubber seals and hoses. John That is a very simplistic take. Diesel bug thrives on the interface between the diesel fuel and the water layer. Whether or not you use FAME free diesel, there is likley to be water in your tank. It gets in off the deck filler and condensation and whilst it's true that the ethanol component of most diesel fuels on the river will also contribute to the problem, searching for and finding FAME free diesel will not prevent the problem. And, that's without considering the cleanliness of the yard's tank that's serving you the fuel or the tanker that delivered it to the yard. I am convinced that a tanker delivered 50-70 litres of water to one of my heating oil tanks last year as there's no way that the **&T that I pulled out of it that fouled a boiler had just been building up over time. I pumped gallons out of that tank, from the bottom using a purpose made pickup tube that, if present prior to the delivery, would have fouled the boiler pump yonks ago. My point being that the supply chain can be as much of a problem as your tank. Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted September 22, 2021 Share Posted September 22, 2021 we at Horning pleasurecraft are £1.20 for Diesel so not the cheapest in horning but pump access is easy.. we can service virtually anything so depending on what you have will determine the price. Give George a ring on 01692 630614. 1 Quote Link to comment Share on other sites More sharing options...
Oddfellow Posted September 22, 2021 Share Posted September 22, 2021 1 hour ago, C.Ricko said: we at Horning pleasurecraft are £1.20 for Diesel so not the cheapest in horning but pump access is easy.. we can service virtually anything so depending on what you have will determine the price. Give George a ring on 01692 630614. I can't imagine what you mean about pump access....... Quote Link to comment Share on other sites More sharing options...
OldBerkshireBoy Posted September 22, 2021 Share Posted September 22, 2021 On 21/09/2021 at 12:04, Chelsea14Ian said: On the South,as said most hire company yards will sell.Always best to ask in advance if possible.Brooms most times I fill up there,WRC. Beccles across from the YS. If you are using Brooms mostly for your diesel then you are passing Swancraft where I believe it is cheaper Ian. Quote Link to comment Share on other sites More sharing options...
vanessan Posted September 22, 2021 Share Posted September 22, 2021 Brooms appears to be the most expensive place on the Broads for almost anything. (I did notice that from October no cash will be accepted, only cards. Going to make a £3 water fill up quite expensive for them methinks what with the time needed to process a card!) Quote Link to comment Share on other sites More sharing options...
grendel Posted September 23, 2021 Share Posted September 23, 2021 12 hours ago, C.Ricko said: we at Horning pleasurecraft are £1.20 for Diesel so not the cheapest in horning but pump access is easy.. we can service virtually anything so depending on what you have will determine the price. Give George a ring on 01692 630614. @C.Ricko I know roughly where you are, is it down the same dyke as boulters marine, but not sure where down that area you are, I do know the absolute easiest fuel in horning is at the yard next door to the new inn, as its right on the river, any chance you could pin a map to show us where your fuel dock is plese? Thanks Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted September 23, 2021 Share Posted September 23, 2021 is it down the same dyke as boulters marine, No - Not the same dyke as Boulters but the very next one down river. The Dyke / Entrance is immediately after the last property on the Stbd bank if going down river. Obviously if approaching up river then its the first dyke immediately before the first property on the Stbd bank Griff 2 Quote Link to comment Share on other sites More sharing options...
Mouldy Posted September 23, 2021 Share Posted September 23, 2021 In other words, heading up river, it’s the first Dyke on on the starboard side after passing the one that Facebook doesn’t allow you to name!! 1 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted September 23, 2021 Share Posted September 23, 2021 Thanks everyone, isnt that the one that says no hire boats? (not that it makes any difference when I am on water rail) Quote Link to comment Share on other sites More sharing options...
BrundallNavy Posted September 23, 2021 Share Posted September 23, 2021 25 minutes ago, grendel said: Thanks everyone, isnt that the one that says no hire boats? (not that it makes any difference when I am on water rail) It does indeed. Quote Link to comment Share on other sites More sharing options...
C.Ricko Posted September 25, 2021 Share Posted September 25, 2021 On 23/09/2021 at 06:36, grendel said: @C.Ricko I know roughly where you are, is it down the same dyke as boulters marine, but not sure where down that area you are, I do know the absolute easiest fuel in horning is at the yard next door to the new inn, as its right on the river, any chance you could pin a map to show us where your fuel dock is plese? Thanks Sorry for the delay but it seems the answers are here before me! Thanks everyone .. 1 Quote Link to comment Share on other sites More sharing options...
