Alphacraft hurricane
Mandybstorm
On Sunday, they tried again to tow the boat off with Titan. Several large seagoing craft passing were asked to pass at speed to create as much wash as possible to assist with the attempts to encourage her off which again failed. Here is a link to a video taken by one of the boats during the attempt (hope the link works!)  "https://www.facebook.com/video.php?v=10206257805268263&set=vb.1359485995&type=1"
From what I could see when passing, the stern is completely out of the water, meaning she is sitting firmly on her keel and skeg, making it very difficult to drag her sideways.
Looks like it will need a very high tide or lifting & pulling so that it twists on the mud in order to slip back in, transom first. But I guess as John Cressy is clearly part of this, there must be some reasons why this hasn't been tried. What is the ground like on the bank?
Must be a very troubling time for Alphacraft.
why not pull her towards the bridge? did they try with one boat along side and the other snatching off a long line round the transom?
obviously much easier to do the job from my arm chair!
She is only about a boat length from the bridge protection. Was at Somerleyton on Monday's high water and she still had a very noticeable lean so nowhere near fully afloat. The tide prediction was only 1cm higher than Sunday when they last tried to release her, with the aid of some fast boats trying to create wash to dislodge her. Not sure of the H+S implications of boats speeding through the bridge. Certainly looks like John had an interesting ride aboard Titan. :grin:
Looks like Saturday the 18th onwards will be the best chance of her coming off. Monday's predicted high was 1.82m and that was far from enough.
From my arm chair, I have been wondering why a long rope and a winch on the bridge is not the answer.
I might be talking out of my a**e here, but could not a teleporter
forklift from nearby get near enough to give her stern a helping
lift back into the water?
Assuming she weighs around 8-10 tons, lifting the transom only
would most likely only need about 2-3 tons force to do it, needing
a lift of only maybe 2ft to clear the skeg and once the skeg and
rudder are clear of the bank she could be lowered again and the
slope of the bank would allow her slide back in if done at high tide.
Again I might be wrong, but I believe that the bank there is quite
sturdy and could support a farmers teleporter.
I'm sure someone will be along to prove me wrong  :naughty:
In answer to Jonathan, it might damage the skeg and rudder, perhaps
even put a hole in her there if she catches anything.
I think with an 8 tonne boat, not afloat would require something capable of lifting close to 5 tonne, depending on the pivot point, just to raise the stern.
It could be raised with jacks and long timbers slid under in several places, and then slide it sideways into the water. This will require access to the land, and maybe specialist equipment, well, my trolley jack can lift three tonne, a couple of them lol...
A few wooden sleepers... A decent 4x4 with a winch and ground anchors might also be needed.
Clearly waiting until an exceptionally high tide and waiting until it floats off is the cheapest option, if the boat is not on hire for a week or two, after all, it is not in danger of any further damage.
I just hope the hull isn't holed, or cracked, when it gets back to the yard, it will have to be lifted, checked over and any repairs done before she is out on hire again.
But this is what these hire companies have to budget for.
Looking at the Hoseasons site Hurricane which goes under Alpha Spitfire Class the site shows bookings available from May 5th. That could of course be Spitfire and Mustang so three in that class. Lets hope the tides in a week or so get it moved off the bank safely.
cheers Iain.
Ok, here is my daft idea to get Hurricane afloat again. If there is a fire tug handy and you skoosh the mud into oblivion with the power hose under her keel, would she not slip back into the river/ Aye ok i'll get my coat! :naughty:
cheers Iain.
I am beginning to have a bit of sympathy for taller boats at Somerleyton
Can you tell what it is yet?
No? What about the one on the bridge?
See your point Matt.
We passed under the bridge not long after the boat had gone aground and looking at the red flag the wind was blowing in the exact opposite direction that day so the reeds were not obstructing the height board.
What I did notice at the time was that the upstream board was showing at least a couple of more inches clearance that the downstream board at the moorings.
Roy
