Betty1 Posted April 9, 2018 Posted April 9, 2018 I'm going to get a boat survey done before myself and money depart. Will a survey check engine condition? Sent from the Norfolk Broads Network mobile app 1 Quote
CambridgeCabby Posted April 9, 2018 Posted April 9, 2018 You can request a separate engine survey from the surveyor , standard survey doesn’t go into too much depth as to engine condition. with ours they offered to undertake an engine oil survey which checks for metal particles etc in the oil , we didn’t take them up on that as didn’t believe it to be worthwhile . 1 Quote
Simon Posted April 9, 2018 Posted April 9, 2018 I had a standard boat survey then I had a separate marine engineer check the engines and outdrives in more detail. He also came with me on the sea trial. 1 Quote
Guest Posted April 9, 2018 Posted April 9, 2018 Hang on I thought you had just bought a boat ie Carol Ann ? Quote
Guest Posted April 9, 2018 Posted April 9, 2018 21 minutes ago, Ricardo said: Hang on I thought you had just bought a boat ie Carol Ann ? I think its at the STS stage Quote
Guest Posted April 9, 2018 Posted April 9, 2018 9 minutes ago, 40something said: I think its at the STS stage Ah see , I figured the deal was done that's why it confused me somewhat . Quote
Vaughan Posted April 10, 2018 Posted April 10, 2018 When the company I worked for was sold, the new managers decided to have an oil analysis done on all the engines, which was a bit strange as they had not had one of the boats inspected or surveyed before they bought them. The results were bizarre and totally useless. Some engines with 11000 hours on them were perfect, whereas brand new ones were condemned as in need of a re-build. Even our new wunderkind management didn't bother to repeat that exercise. Quote
NeilB Posted April 10, 2018 Posted April 10, 2018 43 minutes ago, Vaughan said: When the company I worked for was sold, the new managers decided to have an oil analysis done on all the engines, which was a bit strange as they had not had one of the boats inspected or surveyed before they bought them. The results were bizarre and totally useless. Some engines with 11000 hours on them were perfect, whereas brand new ones were condemned as in need of a re-build. Even our new wunderkind management didn't bother to repeat that exercise. They probably mixed them up !! Oil analysis is becoming fairly common now in commercial and industrial engine use. With regular sampling you can extend servicing by quite a margin and it’s very sophisticated now. Bear in mind larger engines use several gallons of oil per change and some are working up to 24 hours a day in a few applications, downtime is also an issue. 2 Quote
Guest Posted April 10, 2018 Posted April 10, 2018 50 minutes ago, NeilB said: They probably mixed them up !! Oil analysis is becoming fairly common now in commercial and industrial engine use. With regular sampling you can extend servicing by quite a margin and it’s very sophisticated now. Bear in mind larger engines use several gallons of oil per change and some are working up to 24 hours a day in a few applications, downtime is also an issue. We used to evaluate the trend rather than one single sample,if one sample was "odd" we'd re sample before taking action, We also found it important to regularly check new oil as sometimes the blenders would change the additive package and give strange results Quote
JanetAnne Posted April 10, 2018 Posted April 10, 2018 Are you telling me that wiping the dipstick between finger and thumb and rubbing the two together is no longer the recognised evaluation technique for engines? 3 5 Quote
Guest Posted April 10, 2018 Posted April 10, 2018 5 minutes ago, JanetAnne said: Are you telling me that wiping the dipstick between finger and thumb and rubbing the two together is no longer the recognised evaluation technique for engines? The blacker and more gritty the better, some small bubbles.....perfect Quote
Smoggy Posted April 10, 2018 Posted April 10, 2018 If there's nothing in the oil big enough to read a part number off it'll be fine....... 1 Quote
Betty1 Posted April 10, 2018 Author Posted April 10, 2018 Hang on I thought you had just bought a boat ie Carol Ann ? It is sold subject to a survey. It's a long story. The owner is away at the moment. Sent from the Norfolk Broads Network mobile app Quote
quo vadis Posted April 10, 2018 Posted April 10, 2018 5 hours ago, MauriceMynah said: Wot's oil? This Quote
Springsong Posted April 10, 2018 Posted April 10, 2018 Fit a Mini sump plugs with its little magnet. 1 Quote
Guest Posted April 10, 2018 Posted April 10, 2018 7 hours ago, MauriceMynah said: Wot's oil? Ask Robin his rib has no idea what it is that oil has more holidays than me Quote
LondonRascal Posted April 10, 2018 Posted April 10, 2018 I have the right oil, in the right place just happen to have used a bit more of it than one is meant to and in order to remove the oil I now need to remove the oil tank and several hoses to get at a place i can suck the oil from the actual engine from. 1 1 Quote
ChrisB Posted April 11, 2018 Posted April 11, 2018 13 hours ago, springsong said: Fit a Mini sump plugs with its little magnet. I had clean forgotten those. They used to be covered in spiky bits on the first few oil changes. Quote
BroadAmbition Posted April 11, 2018 Posted April 11, 2018 On Flea Bay, nowadays you can purchase magnetic sump plugs for most engines, helps if you know the thread used on the sump though. I fit them to all my vehicles including, Tiger and Beta alike. Another standard application I do is to administer 'ZX1' to engines, gearboxes, differentials and also upgrade air filters to K&N type, they save a fair bit on never having to buy any more air filters during servicing along with improved air flow = improved mpg I fitted a K&N example to 'B.A's Beta - that was one air filter too far as the induction noise was unacceptable so off it came to have the manufactures one put back on Griff Quote
Bexs Posted April 11, 2018 Posted April 11, 2018 Down here on the south coast the surveyors are generally not qualified enough in mechanics to comment in any detail on the state of a engine, might be different in Norfolk... Marine engineers are normal used to do an engine inspection and sea trial, as well as a surveyor doing the survey. Quote
socrates Posted April 11, 2018 Posted April 11, 2018 I hope you find a decent surveyor, go with recommendations. Before we bought BG, We had BG surveyed by a qualified surveyor and the report was not worth the paper it was written on. I found far more things wrong with the boat than the surveyor found, he should have gone to Specsavers. What concerned me most was that the survey did not report on what was nothing short of a deadly gas system and an engine with a cracked cylinder liner. Fortunately, I had noticed these things prior to purchase. I am still not sure how much depth a survey goes in to, but I would expect a lot for the money they charge. My advice to you would be to go over every inch of the boat yourself, then get an idea of the cost of making good the faults you have found. Quote
Simon Posted April 18, 2018 Posted April 18, 2018 On 10 April 2018 at 14:06, Betty1 said: It is sold subject to a survey. It's a long story. The owner is away at the moment. Sent from the Norfolk Broads Network mobile app Just wondering if you had had the survey done yet and how it went? Quote
Betty1 Posted April 18, 2018 Author Posted April 18, 2018 Just wondering if you had had the survey done yet and how it went?No survey, because of a change of plan. Sent from the Norfolk Broads Network mobile app Quote
Guest Posted April 18, 2018 Posted April 18, 2018 22 minutes ago, Betty1 said: No survey, because of a change of plan. Sent from the Norfolk Broads Network mobile app Does that mean your still looking as I know of a alpha 32 that's pretty nice n under 20k . Quote
