Martham Boats Have Added Broadland Minstral To Their Hire Fleet
Tyna
3 hours ago, Mouldy said:
Hmmm.  There’ll be an awful lot of damage to the gel coat forcing that under the bridge when the river levels are high!
I was wondering about the bridge practicalities for this boat. I know they can get the woodies through with less than 6 foot but I'd have thought this would need 6 foot 3 or thereabouts?
Interesting little boat, I have spent a long weekend under the Bridge and enjoyed every minute of it. Now that Bridge boatyard on the Fens have withdrawn Sunstar it will be the only centre steer Elysian 27 for hire in the UK. The only issue is that Bridge which isn't getting any better I wonder if it has been  modified to lower its air draft,  I would have  thought this would be one of the taller members of the fleet, not sure what Silver Jubilee needs. As an aside I spotted Silver Jubilee 2 at Windsor/Eton recently I always wondered where no 2 went as 1 and 3 are still on hire
Neil
Great fan of both versions of the Elysian 27. This looks a super little boat and nicely renovated.
I'm lucky to have an old pilots Hoseason brochure that gives the air-draft for those craft that could get under. Sharmaine from Alan Jonson Boats and Dawn Mist from Dawncraft are shown as 6' 9". I may be wrong but does not (or had not) Potter Heigham an inch more than Wroxham, the problem being the profile of Potter's uneven arch?
The centre cockpit version first appeared for hire in 1967 with Dawn Mist 1-6 from Dawncraft and Sea Mist 1-6 from A. G Ward, both Jenners group yards and were marketed as 5 berth craft, which must have been a little intimate!
Fred
Fred I don't wish to doubt the brochure you have which I am sure is the bible for bridge heights required however if this boat needs 6 ft 9 it will be stuck Martham side for most of the season. Having seen many an Elysian/Bounty 27 go through at less than 6ft 6 I would have guessed 6ft 3 might be possible although happy to be proved wrong and to be honest they tend to be the aft cockpit version I have seen go under. Still I nicely fitted craft ideal for a short breaks. Not sure  about the davits at the stern though they could get in the way or cause issues at some moorings, perhaps they will be removed
Neil
Sorry I made a typo there. The air-draft quoted is 6' 8", which still makes your point valid Neil. The aft cockpit versions air-draft varies from class to class. From 6' 6'' to 6' 8", including Whispering Reeds Pompey. Hoseasons holiday hints handbook  for 1977 gives headroom at AHW of 6' 9" at centre dropping at 4' either side to 6'  and 6' 1".
Fred
Our old MK1 aft cockpit Elysian 27, 13 years ago that we kept at Martham was good for 6’ on PH bridge, according to the BA indicator boards.  I would think there is not too much in between the centre and aft cockpit versions? I guess time will tell, remembering it will be the yard that takes it through.
Our current boat an Ocean 30 needs 6’4” at PH as per the pilots gauge, it’s tight but made it, (a very windy April 2015 after re launch at Martham), I would have thought given the extra beam and height of the O30, the centre cockpit Elysian would need less?
Great to see a yard adding a boat like this,  a fantastic modernised example it is too. There still appears to be a hire market for this size of boat which are a little thin on the ground elsewhere at present, again time will tell, however the small injection of similar sized original built wooden boats at MBDC appears to be working well.
Cheers
Paul
I'm sure they know what there doing putting this boat into the fleet. She looks very smart inside and kinda fits in with the traditional broads thing..but foe me she's a tad on the expensive side. A week in Sept 917 quid. Umm not so sure on that and that certainly won't last if it keeps getting stuck the wrong side of the bridge.
Broadland Minstrel was completely rebuilt in Martham's DIY shed by a chap called Peter who then used her for himself and his wife. That was about 10 years ago (I was there restoring Chloe Jane at the same time). If I remember correctly she was one of very few that had never been a hire boat!
When he had finished her he was having trouble getting the waterline straight so I fired a laser beam along her hull for him. Unfortunately his calculation was slightly out resulting in the waterline being perfectly straight but an inch too low all the way round and a constant stream of phone calls from people concerned she was sinking!
Peter made a lovely job of her and I would think she must still be one of the best out there.
  • Like 12
4 hours ago, Victoryv said:
The plan is to cover the hull and top structure in wood effect sticky back plastic, should look spot on!
Very Jolly Ritchie!
2 hours ago, BrundallNavy said:
6ft showing around 2pm today.
Did you buy much?
I think 6ft 8inches for an Elysian CC is being generous, I've taken mine under Wroxham and potter at less than that..
The Elysian is quite narrow at about 9ft 6inches, that's narrower than some of Marthams other boats, which helps getting the cabin through the bridges.
