grendel Posted January 8, 2017 Author Share Posted January 8, 2017 As promised a few more of the noggins ready to support the deck, to be honest the model doesnt really need these to support the deck, but I figure I might as well do the thing properly, plus they will give the hull a bit more rigidity. at the front of the hull there will be full width deck supports, these will need to curve, so will need steaming, I will soon need to figure where the front of the cabin needs to be. 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 8, 2017 Author Share Posted January 8, 2017 One final bit of work for today, another former cut, this for the front deck beams (it may also suit the roof beams), and the first deck beam steamed up and in the former. now when I steam a rib, I can throw a section of 5mm square in and heat up 2 pieces with one steaming, though the thicker wood could do with 5 minutes more steam than the ribs, this can be finished off after the rib has been fitted in the former though. 1 Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted January 9, 2017 Share Posted January 9, 2017 6 hours ago, grendel said: Of course if I had known I would probably have volunteered like a shot. Thats how all wooden boat owners start, then, about half way through the 'project' they wish they had run a mile in the other direction! 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 9, 2017 Author Share Posted January 9, 2017 So this evening another rib was put in, another rib steamed and formed, a second deck beam shaped, and in the rear cockpit, a pair of supports added for the sides of the stern lockers, plus another pair of deck noggins inserted, sounds a lot, but that was just 25 minutes work. 2 more supports will be needed in the stern cockpit, to support the floor, this will need to be removable to get to the steering gear. It will also need to be decorated to simulate the holly teak flooring. 3 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted January 10, 2017 Share Posted January 10, 2017 Wow, more great stuff, and the idea of using a plug for the tiller - Brilliant, just how do you do it? Griff 1 Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted January 10, 2017 Share Posted January 10, 2017 It's cos he's down to EARTH 5 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 10, 2017 Author Share Posted January 10, 2017 tonight the front support for the rear cockpit floor has been fitted, another couple of deck supports are in place and another rib and deck support have been steamed, yesterdays rib is glued. 4 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 10, 2017 Author Share Posted January 10, 2017 I now know just how much room I have in the stern for the steering gear, to be honest I want the tube for the rudder to end as high as I can to make sure its above the water line, even though it will be greased, we dont want leaks, and we dont have the facility for a proper stuffing box and grease nipple. 2 Quote Link to comment Share on other sites More sharing options...
FairTmiddlin Posted January 10, 2017 Share Posted January 10, 2017 12 hours ago, MauriceMynah said: It's cos he's down to EARTH Just a bit of Positive thinking 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted January 10, 2017 Share Posted January 10, 2017 It's cos he's down to EARTH Just a bit of Positive thinking As long as it's nothing Negative Griff 2 Quote Link to comment Share on other sites More sharing options...
MauriceMynah Posted January 10, 2017 Share Posted January 10, 2017 Aye, Fuse like our Grendel 1 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2017 Author Share Posted January 11, 2017 7 hours ago, MauriceMynah said: Aye, Fuse like our Grendel I'm Neutral in all this. 2 Quote Link to comment Share on other sites More sharing options...
FairTmiddlin Posted January 11, 2017 Share Posted January 11, 2017 F use a jolly good fellow.. F use a jolly good fellow 1 Quote Link to comment Share on other sites More sharing options...
riyadhcrew Posted January 11, 2017 Share Posted January 11, 2017 Just ''phase'' it in gently people. 1 Quote Link to comment Share on other sites More sharing options...
BroadAmbition Posted January 11, 2017 Share Posted January 11, 2017 Apparently a baker up here near Wetherby was killed in the bakery this morning, he stood on a tea cake and a current shot up his leg Griff Quote Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2017 Author Share Posted January 11, 2017 Ah well - all these plugs keep this thread popular, and at the top of the forum, I will just have to Socket to them with the build progress later. 1 Quote Link to comment Share on other sites More sharing options...
ranworthbreeze Posted January 11, 2017 Share Posted January 11, 2017 19 minutes ago, BroadAmbition said: Apparently a baker up here near Wetherby was killed in the bakery this morning, he stood on a tea cake and a current shot up his leg Griff Quote Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2017 Author Share Posted January 11, 2017 I shall of course have to watch out for Griffs puns on the forthcoming AMP, as when it comes to jokes and pranks he is a bit of a live wire, shocking I know, but it is the case. 3 Quote Link to comment Share on other sites More sharing options...
JennyMorgan Posted January 11, 2017 Share Posted January 11, 2017 41 minutes ago, grendel said: I shall of course have to watch out for Griffs puns on the forthcoming AMP, as when it comes to jokes and pranks he is a bit of a live wire, shocking I know, but it is the case. Only wish he'd come up with something new occasionally Reckon that he got most of his stuff from the Wilfred Pickles joke book for boys! 3 Quote Link to comment Share on other sites More sharing options...
JanetAnne Posted January 11, 2017 Share Posted January 11, 2017 'Watt' you all need to remember is that Griff spends a lot of time away from 'Ohm' which allows plenty of time to 'Amp'ly' regenerate his supply of witisism's. 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 11, 2017 Author Share Posted January 11, 2017 Right then, back to the business in hand, this evening another rib glued in , some more deck supports and new rib and deck beam steamed, now if you look at the pictures you will see I forgot to get a picture of the new deck beams, plus when I took the picture of the bending of the new parts you will see I have changed formers to the next one forward, and that I nearly forgot the deck beam, only spotting it and getting it into the former when I went to empty the condensation from the steaming box. the neutral pin of the plug has now also been converted to a tiller arm, just needing the actuating holes drilling (its just visible next to the deck beam former. 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 12, 2017 Author Share Posted January 12, 2017 tonight was a bit of a late start due to the snow and time spent driving home, firstly when I took the rib out of the bending jig I spotted a crack, so this one was rejected, no rib fixed tonight, some more deck supports fitted and a new rib and deck beam steamed up. 2 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 13, 2017 Author Share Posted January 13, 2017 tonight that replacement rib is fitted, some more deck supports fitted and tomorrows ribs and deck beams steamed up. 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 13, 2017 Author Share Posted January 13, 2017 after posting that I had a sudden impulse to install one of the front deck beams. 3 Quote Link to comment Share on other sites More sharing options...
grendel Posted January 14, 2017 Author Share Posted January 14, 2017 so far this morning I have added more deck beams at the front, some more deck supports and glued in place another rib, as I type the steam is softening the next rib and front deck beam. 3 Quote Link to comment Share on other sites More sharing options...
