    Forum Shop
LondonRascal
Happiness is not a destination ... if you think of it as something to be achieved then you may never arrive.
Robin when you renamed Indy did you have to de-register it, I keep meaning to find the video with the original name on it did it have Hull (port) under the name.
I was thinking they have a log of the boat plus the radio reg was linked to the boat name.
The trip boat I was on that was registered in Hull even thought it's never seen 10 mile from Leeds.
No, because her registration had lapsed. I was going to go and register it again as Part 1 and still could, but get this I need to prove her weight, and I understand I need a Surveyor to do this.  I could go for a SSR registration, but since she is on the Broads now this again is very much 'down the list' of things right now.
As to the radio registration that was easy, but the EPIRB was a bit more of a process to have registered to myself from the last owner.
Happiness is a decision we can make every morning. I am happy to be coming to Wroxham in shore accommodation with a day boat to use for the week. Will wave like mad at any NBN friends.
It has been sometime since I had anything to really report..But NYA have been working away and solving issues and finding more to then solve and I am happy to say that:
I have two sets of brand new belts fitted and to the correct tension with new screws to hold the safety covers in place correctly too.
The ongoing coolant leak was traced to the bodge where a threaded valve had sheered and been 'glued' in with some gasket putty. This was removed, the engine block where it attaches cleaned up and new threads put into the metal to accommodate a new valve and now all that is awaited are the correct Yanmar seals. The thermostat housing was also removed and taken to the workshop to clean up and inspect.
Previous dangerous bodge:
New valve connected to thermostat housing
Work now moves to the RIB engine and oil system.
Decided not to diy the job then. should have been easy with a small suction device to remove the oil
Duly bought small suction device to remove the oil - along with new battery, and fully synthetic oil of the correct grade to go back in. Having sucked out just over 200ml no more would come - consulted service manual on the operation and found I had only sucked out the contents of the oil tank - which should be free of oil when the engine is not running. In order to remove the rest of the oil the tank and a bunch of hoses would need to be removed to obtain actual access to the engine and from there the sump.
Since I did not have the hose clamp removal tools I stopped and sent an email to Shaun and away went the stress and hassle.
Should anyone want a 60w, 12v oil suction pump which provides a flow rate of 5L per minute let me know. No charge.
If a fitter did that bodge in my employ, he would be getting his p45, that`s really poor quality work. Sorry rant over, hope you enjoyed your bacon butties :default_icon_e_biggrin:
Defiantly have that off you Robin , I do loads of oil change's a yr mostly 4 its a proper pain with a manual pump , how much ?
It is free - I have a number of things to hand out to a few people that I have made notes of bits and bobs like light fittings off Trixie. Thing is the pump is not with the boat but I will see about getting it somewhere suitable to collect and let you know via PM.
Many thanks Robin , no rush I know your rather busy at the moment picking up Trixie n forum meet etc :default_beerchug:
Robin after Shaun has worked his magic on the rib, I am happy to go with him to do an essential river test on her and report back?
Obviously to make sure there are no oil leaks, cooling is working and she ticks over nicely. Oh, and for the sheer hell of the blast!!!! :default_icon_e_biggrin:
Create an account
Register a new account
Sign in
Sign In Now
  • NBN Mobile App
    Our new mobile app is available now on Android and iOS!
    Get it on Google Play
