Water Rail Out And About.
1 hour ago, YnysMon said:
Is that bad news? :default_dunce:
To put it into easy to understand terms,  it's the vital bit that connects the uppy downy sucky squeezy bangy blowy bit to the spinny roundy bit that makes the water movey choppy thing work.
It should be a tad less bendy and lacking the blue effects round the little hole.
In less technical terms it's buggered.
  • Haha 9
1 hour ago, Vaughan said:
So do you suspect a blocked oil gallery?
No. The little end is absolutely fine, it's just oily in the picture.
Basically the engine ran away and hydralocked. On removing the head, no's 1&3 pistons were dry and fine but no. 2 had about 150ml of oil on top of it. That piston no longer made the journey to the top of the bore so engine out and bent rod discovered.
