Wonderwall Posted December 12, 2015 Posted December 12, 2015 Hello folks, it's me again. This cold weather is stirring my summer broads need a fix mentality !! The family are coming round!!! Just checked the tides for early July and was just wondering about the following , all advice is greatly appreciated. So, my question is, if one is approaching Yarmouth from the North , with the tide and you want to moor up at Yarmouth where do you turn, so as to moor against the tide ? Especially if you could not get under the bridge? i appreciate it is not a scenario you should really be putting yourself in, and would like to think I would time it so I'm not in such a position but let's say I underestimated the height of the water . Do you attempt to moor with the tide or go for the turn , which if my memory serves me correctly it's a part of the river frought with danger I.e. Strong current , not very wide and a few obstacles around. It must happen quite regular with inexperienced pilots , what's the drill? folks, see you in July!!!!!!! Quote
riyadhcrew Posted December 12, 2015 Posted December 12, 2015 Hi Wonderwall, I've done it once with the help of the guys at the yacht station. They had me come in and held the bow rope. The tide swung the stern all the way round and job was done. Quote
ranworthbreeze Posted December 12, 2015 Posted December 12, 2015 We just pass through Yarmouth when the tides allow, usually Tan is hiding below. From a personal point of view I can see no benefit of mooring there, if it was an off river marina with floating pontoons that would be a different story. Regards Alan 2 Quote
JennyMorgan Posted December 12, 2015 Posted December 12, 2015 When I have gone through Yarmouth and actually needed to moor, rare, I haven't bothered to turn into the tide, indeed in a sailing boat using the tide it would be a pretty pointless manouvre. Just headed alongside with a rope on the stern which I have either dropped over the cleat on the stern of another boat or a post on the shore, or a Ranger has taken it & made fast. I would then let the rope surge for a yard or two rather than come to an abrupt halt, never been a problem. The Rangers know what they are doing, great help. Quote
NorfolkNog Posted December 12, 2015 Posted December 12, 2015 Another option would be to time your arrival at GY just after slack water. At least you could come in to moor against the incoming flood. If we visit GY we tend to moor at Brundall and catch the train. Quote
Oddfellow Posted December 12, 2015 Posted December 12, 2015 Turning against a flowing tide can be challenging, but simply give yourself enough space and do everything without panic. Note how the current is treating the boat, it might be assisting in the turning process initially, but this is likely to change as you try to get further than 90 degrees. Bursts of a lot of power are often useful that a full-long-term-burn but few situations are identical, so take it easy. As for where to turn, that all depends on where there's space to moor. You really don't want to turn 100 yards beyond where you want to end up. 1 Quote
ExUserGone Posted December 12, 2015 Posted December 12, 2015 You can turn early if space is available (and less onlookers) and stem the tide to the mooring of choice by simply going forward slower than the water is going past so you effectively go backwards with all the steering and control of going forwards and can come to a complete halt in a near instant with the throttle, steer to one side a little bit and the boat will gently glide sideways to that side (ferry gliding). It's a good thing to practice when going against the tide sometimes. 1 Quote
BroadAmbition Posted December 12, 2015 Posted December 12, 2015 Easy answer - Avoid stopping at Grot Yarmouth at all costs! Last time it flooded there was tens of pounds worth of improvements as a result Griff 8 Quote
Matt Posted December 12, 2015 Posted December 12, 2015 Bursts of power would be my advice. and room to do it and a bow thruster helps..... Quote
littlesprite Posted December 12, 2015 Posted December 12, 2015 Whether you are coming about, mooring, or any other difficult manoeuvre the rule is the same, look for the largest most expensive bling boat and do the manoeuvre there, help is on hand almost immediately. 6 Quote
MauriceMynah Posted December 12, 2015 Posted December 12, 2015 Ahh, this is where I need my tin hat as I'm going to say something that goes against all the advice you'll ever be given, but first an observatioin. ..... I am reminded of an old Dave Allen joke about a fellow asking an Irishman for directions. The Irishman said,,, "Ahh well now sir, I wouldn't start from here". The question was " if one is approaching Yarmouth from the North , with the tide and you want to moor up at Yarmouth where do you turn, so as to moor against the tide ? So, just for the sake of argument we shall say that the boat is travelling from the northern broads. We shall perhaps add that it's an outgoing tide, Should he turn at such a hazzardous spot or attempt to moor stern toi the tide? For my part (and this is where I am in contention with all perceived wisdom) I would moor stern to the tide. Ok, Yarmouth moorings are on the port side in this situation. What I am about to suggest is tricky (but fun) if you are trying to moor between two other craft but here goes. You approach the mooring as close to the bank as the moored boats allow. As you are alongside your chosen spot go astern. Keep the engine going astern until you are stationary to the bank, at which point you turn the helm just a bit to starboard. This starts to bring the stern towards the bank. DO NOT PUT THE HELM TOO HARD TO STARBOARD, this maneuvour has to be done gently to maintain control, and it's not easy. As I'm frequently on my own I have to moor portside on to the bank so I've practiced this, making a right cock of it at Reedham (with large audience) and perfectly at the Berney arms (deserted) Thus, what I would advise is that if you can you practice this trick somewhere with a good flow but some space. Done well it looks REALLY cool! 7 Quote
ExUserGone Posted December 12, 2015 Posted December 12, 2015 Would that depend on wether you have a LH or RH prop? I'm guessing prop kick could have more effect than the rudder going astern against the tide. As a disclaimer I've just moved from twin outdrives to twin shafts so on a new learning curve myself. Quote
marshman Posted December 12, 2015 Posted December 12, 2015 Don't like Leo's idea of going downstrem backwards - unless you hav about 50' of chain out the front! I can see the logic but its a long way from the wide spot just south of Marina Quays to the YS - makes so much more sense if you really do want to go to Yarmouth for your chips to turn around Marina Quays and head back up stream against the ebb for a bit. Alternatively have another beer in the Bridge at Acle and just delay your departure, or at Stokesby if you can get in!!! If thhey tides are neaps you might get away with either a quick turn, or even a controlled downstream approach, but I would be pretty worried if I was forced to do either on a decent Springs ebb!! Sit down and time arrival at slack - plenty of advice around and 1/2 to 3/4 hour either side and it will make life so much less stressful!!! Quote
MauriceMynah Posted December 12, 2015 Posted December 12, 2015 Absolutely right MM, I'm just taking the question in the "This is now and this is the situation I'm in. What should I do?" It's no good shouting at the man in the water "You shouldn't have fallen in there, you should have fallen in at Salhouse where the water's calmer." We are all capable of mis-timing the Yarmouth approach! 1 Quote
Gracie Posted December 12, 2015 Posted December 12, 2015 My advice would be to do as we do, cruise sraight past without stopping, male helmng of course and all females (as with Tan) hide below decks cowering lke gibbering idiots, trust me when I say that I am an expert at the last bit lol I don't mind Yarmouth so much but do absolutely hate the YS Moorings Grace 3 Quote
JennyMorgan Posted December 12, 2015 Posted December 12, 2015 I'm with Grace when it comes to YH moorings, especially when moored up three abreast, albeit that's rare nowadays. Yarmouth itself can be fun, scoffing chips, bacon rolls and mushy peas on the Market or wandering along Kings Street and Regent Road admiring all the tack. Yarmouth is Yarmouth, might even spot one or three of Poppy's famous Gt Yarmouth Girls. That reminds me, crabs, a local delicacy, worth looking out for, especially down the sea-front. 3 Quote
JennyMorgan Posted December 13, 2015 Posted December 13, 2015 I suspect that all hire craft have enough horses in the engine compartment to be able to go against the tide in Yarmouth so going through the bridges and out onto Breydon is an option. When you pass the large yellow post turn round and go back up the river against the tide so you can then moor against the flow of the river. Be a darn sight easier than trying to turn in the river. Personally I can't see what's so hard about getting the tides right though. 5 Quote
BroadAmbition Posted December 13, 2015 Posted December 13, 2015 As long as there is enough airdraft at the bridges, JM post of going through, turning then coming back against tide is the sensible safe option for me Griff 1 Quote
Wonderwall Posted December 13, 2015 Author Posted December 13, 2015 20 minutes ago, JennyMorgan said: I suspect that all hire craft have enough horses in the engine compartment to be able to go against the tide in Yarmouth so going through the bridges and out onto Breydon is an option. When you pass the large yellow post turn round and go back up the river against the tide so you can then moor against the flow of the river. Be a darn sight easier than trying to turn in the river. Personally I can't see what's so hard about getting the tides right though. It's not hard I agree. But humans do make mistakes. Maybe not you, but it does and will happen. i only asked in the scenario if you got your timings wrong. 10days is not a long a time to cram all you want to do in a broads holiday, and it is possible for mere humans to not be perfect I was wrong once☹️ 2 Quote
ExMemberBobdog Posted December 13, 2015 Posted December 13, 2015 8 hours ago, JennyMorgan said: That reminds me, crabs, a local delicacy, worth looking out for, especially down the sea-front. Yeah, a friend of mine caught crabs not far from Yarmouth sea front. Soon sorted out with a course of penicillin. 3 Quote
FairTmiddlin Posted December 13, 2015 Posted December 13, 2015 Bobdog Must have been St Peters road 1 Quote
JennyMorgan Posted December 13, 2015 Posted December 13, 2015 Wonderwall, I rely on good advice, a tide table and a watch! Part of the fun of a Broads holiday, planning ahead, as clearly you are doing. There are a number of moorings between Acle & Yarmouth, if you are ahead of schedule then simply moor up for an hour, or just slow down, as the saying says, 'go with the tide'. Arriving late can be a problem for those of us under sail, and it does happen, but most, if not all, hireboats can cope. Getting it right can be very satisfying, the journey is both interesting and enjoyable. FairTmiddlin, personal experience? 2 Quote
JennyMorgan Posted December 13, 2015 Posted December 13, 2015 13 hours ago, Bobdog said: Yeah, a friend of mine caught crabs not far from Yarmouth sea front. Soon sorted out with a course of penicillin. Most unfortunate, your friend should have read the signs all along the beach: 'Keep off the groynes', 'dangerous groynes' and similar. Gt Yarmouth groynes are best avoided. 1 Quote
FairTmiddlin Posted December 14, 2015 Posted December 14, 2015 " FairTmiddlin, personal experience? " No Peter Personal knowledge !! Quote
LondonRascal Posted December 14, 2015 Posted December 14, 2015 Last July, I had hired Brinks Royale – not that the name is important but it was a planning hull moulded from a ‘Seawings 305’ which would usually have a couple of hundred horse power and twin engines – but re-configured by Barnes to have a single engine and around 38 horsepower. I left Womack Water with my destination being Beccles. It was not until half way to Yarmouth in the pouring rain I realised I was going to be way too early to get good clearance under the bridges – not to mention I had an issue with the wiper. I decided that I would fix the wiper issue but to do this I would have to turn the boat into the tide and ‘moor’ temporality near the outflow drainage pump on the lower Bure. I am not sure of it’s name, but there is often a sailing boat moored along this stretch of river. Right that’s the background – now I used this as a good test to see how it is to turn a boat when you have a fast flowing ebbing current to deal with. It was actually far less of an issue that I had anticipated but there is a part of the manoeuvre where it can feel alarming. As the boat turns (in this case to Port) more of the hull ‘sees’ the current and begins to be swept in that direction – the boat effectively will be travelling sideways and it is disconcerting, and to a large degree at this stage you are out of control. However, it is a short period before you once more begin to turn, face the current and regain control. You often see this where there are ferries going between two banks of a river such as at Greenwich on the Thames. As less of the boat is ‘seen’ by the current (as the boat completes it’s turn into the current) so the boat will rapidly stop being pushed sideways by the current and at the same time will do what you expect and complete the turn – at which point now heading against the current you will have a lot of steerage control and slow right down. The trick of course is working out a rough estimate of how far the current will carry the boat during this stage downstream – and in the case of Yarmouth towards the dreaded bridges. The more power you have the quicker the turn can be completed and once you have completed it reduce power and the tide will act as your brake. At Yarmouth there is reduced width to do this, but since we don’t see many boats slam sideways into the bridge I guess it can’t be that bad. It is handy to give things a go and see what happens when you are away from other boats and bridges to get the hang of what happens so should you need to do it one day ‘for real’ you won’t be panicked by the boat suddenly doing weird things like going down the river sideways. 1 Quote
